Message 1 of 9
BT Home Hub 3.0A and USB HDD access from iMac
Hello,
I have problem with access to my HDD connected to BT Home Hub 3.0A from my iMac with Lion 10.7.2,
hub is visible from network and USB_Disk as well, but can't get access to HDD/PenDrive.
Everything is working fine from Windows XP or Windows 7 Pro, HDD is visible as "\\BTHUB3\USB_Disk\unknown_13FE0B6A_1"
From Windows can write/read files, but from iMac there is no access to USB_Disk, even if it is visible in Network.
Is there any other way to use password and login to get access to HDD connected to Home Hub 3 ?
8 REPLIES 8
Message 2 of 9
Re: BT Home Hub 3.0A and USB HDD access from iMac
Not sure about the new home hub, but on the old versions you could access it via the IP address 192.168.1.253.
Message 3 of 9
OK, I think that solution for that is to wait about 15min, then OSX is refreshing network places.
Now I have access from Windows and OSX Lion to BTHUB3/USB_Disk via LAN and WiFi.
Happy New Year !!
Message 4 of 9
I have just tried to connect my WD USB drive to the HH3 but it's not seen in Windows ( Win7 ) and when I check with HH3 connection status it says ' File type not supported' - why should this be. If I connect the USB drive to my laptop it can see it fine.
Any suggestions?
Lee
Moderator-Retired
Message 5 of 9
Any suggestions?
Lee
Hi Lee,
I had a bit of confusion myself when I tried plugging in an external hard drive to my HH3 (also using a WD model). What I did to sort it was to leave the HDD plugged in and reboot the HH3, which then refreshed the connection and made it identifiable to both the HH3 and all across my network.
Give this a try and let us know how you get on 🙂
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Message 6 of 9
Too simple for words.
Can't believe I didn't think of that.
I take it security is no different for my files on the WD Drive. It's just as secure being connected to the HUB as it would to the PC.
I  use WPA & WPA2 wireless connection
Lee
Message 7 of 9
when i try this bthub is listed as shared. when i click that i get usb_disk.  When clicking that i get an error message saying "the operation can't be completed because the original item for "usb_disk" can't be found.
Any ideas where im going wrong?  I have tried rebooting the homehub and it makes no difference.
Message 8 of 9
One other matter and sorry if it's digressing from original topic.
What speed should I expect for data transfer or to stream data via USB Hard Drive connected toi HH3 over the wireless network to my laptop.
The data transfer speed mentioned in the HH3 is 130Mbps.
socmwills23 - have you tried rebooting Laptop or PC and also what format is the USB drive?
Lee
Message 9 of 9
i have tried many reboots and the format is fat32.
