goldmankind
Message 1 of 1
BT Home Hub 3 (A)
Hi This is a small extract from the event log from my Router. The different IP's  show different locations worldwide incoming blocked.The 2nd part of the Ip is either the Sheffield or Rotherham BT server.
For example  the 61.156.238.56  at 1.43 am originates in Japan. At that time the Router Firewall was set to block all traffic and the Mcafee was set to block all traffic. Why do i get all these events now which are every 10-15 seconds. Are they constant attacks on the ports trying to Hack me. I have had Broadband engineeers here due to a dropping connection, but they was at a loss to explain these attacks. The modem was changed  but made no difference. I asked for a B series router......... but it seems they havent got any.
     Any ideas what all  this means gratefully appreciated.
                                             Peter
08:55:25, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98->86.171.195.107 on ppp1)
07:45:14, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44->86.171.195.107 on ppp1)
07:31:21, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19->86.171.195.107 on ppp1)
06:40:22, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98->86.171.195.107 on ppp1)
05:23:44, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44->86.171.195.107 on ppp1)
04:08:46, 27 Apr.IN: BLOCK [16] Remote administration (TCP 190.82.88.123:59966->86.171.195.107:80 on ppp1)
03:43:11, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44->86.171.195.107 on ppp1)
03:23:48, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98->86.171.195.107 on ppp1)
02:44:15, 27 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19->86.171.195.107 on ppp1)
02:43:45, 27 Apr.IN: BLOCK [16] Remote administration (TCP 115.239.230.29:6000->86.171.195.107:80 on ppp1)
01:43:02, 27 Apr.IN: BLOCK [16] Remote administration (TCP 61.156.238.56:28528->86.171.195.107:22 on ppp1)
01:28:11, 27 Apr.(223617.950000) Wire Lan Port 4 down
01:27:43, 27 Apr.BLOCKED 3 more packets (because of Packet invalid in connection)
01:27:42, 27 Apr.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.64:5896->173.194.34.129:443 on ppp1)
01:27:33, 27 Apr.BLOCKED 3 more packets (because of Packet invalid in connection)
