Your Homehub can handle in excess of 200 devices so the Customer Service was slightly out with the number suggested.
You may be suffering from wireless interference.
You should try selecting channel 13 on the Homehub. It is the least congested channel. If you get any warnings when you select that channel just ignore them. They only apply in the USA where it is illegal to use that channel.
See link how to change channels
You should make sure that when the wireless drops out you can still connect with a wired connection. If the wired connection also drops out it would tend to point to a possible line fault.
One other thing to check. Since the problem started are there any new electrical appliances/devices in the house and does the drop outs coincided with any electrical items being turned on?
@caisamuels wrote:
I will try what you said, but I don't think it's a line problem, because they said they checked the line and it's fine.
Wireless has nothing to do with the line.
licquorice
I think his reply was in relation to the last paragraph in my post.
Missed that bit.
@caisamuels wrote:
Well I got an amazon echo, but that doesent use much wifi, but I've realised my wifi tends to drop out when I go on my laptop.
Try changing channels first. If that doesn't help and you can definetly establish that the wireless only drops out when you connect the laptop post back the laptop name, model and operating system.
