Message 1 of 3
BT Home Hub 3 on extension socket?
Hi,
Our main socket is upstairs and believe this could be the cause of some connectivity issues on wireless as its very patchy downstairs.
I tried moving the hub from the main socket to the extension socket downstairs but no broadband signal was picked up. I am not sure if the phone socket is working properly now or if the home hub can't work off an extension.
Can anyone advise?
Thanks,
Jack
2 REPLIES 2
Message 2 of 3
Re: BT Home Hub 3 on extension socket?
does your master socket have a filtered faceplate like this original.jpg  if so then broadband will only work connected to this socket
Message 3 of 3
it appears you are on infinity therefore your hub will not work when connected to an extension socket it only works when connected to the Openreach modem
