Hey there,
My BT Home Hub 3 drops it's connection incredibly frequently. The Home Hub 4 is remarkably cheaper than alternatives (£35 + postage, which is something that's important) but I'm concerned about whether there may be similar problems? Looking through the forums there are a few posts but they just seem to be moaning rather than being constructive helpful posts.
Is the HH4 a viable alternative (i.e. provides good speed and doesn't drop out (preferably at all but less often is good!)) or should I be looking at alternate routers and what is the best value for money?
Any advice is appreciated!
Thank you
