I got an upgrade to BT Infinity (FTTC) on Thursday and overall I've been delighted with the performance improvements over ADSL2. The Home Hub 5 was also an improvement over the Hub 3 and the 5GHz performance is particularly good.
Unfortunately, the Home Hub seems to block packet data when I try to update my Tom Tom sat nav system using Tom Tom's "MyDrive" application. The event log on the router fills up with blocked packet messages and the resulting packet loss has corrupted the map downloads for my device and now rendered my £170 sat nav useless. As I write I still haven't managed to solve the problems and now face a 105 Euro repair charge.
Here are a sample of the error messages in the log:
I went to a friend's house yesterday and he has a Virgin Cable Modem and I was immediately able to download the map updates without all the error messages and packet loss. I even used the same laptop at his house that failed when Ethernet connected to the HH5. This is an annoying problem with the Home Hub 5 and I hope BT Tech can sort it out.
I tried the following to solve the issue on the HH5, all to no avail:
Turning off the Firewall on the hub
Tried port forwarding set-up
Tried adding the PC into the DMZ
The Tom Tom update download problems (and packet blocking) start immediately I try to download any updates on MyDrive. The MyDrive application then comes back with a "Check your network" message and advises that a different port is tried. The default port for MyDrive appears to be TCP 4000. I tried 5000 and 5001 as suggested but that didn't help.
If anyone has any advice or help on this, I'd be very grateful.
Maybe I have a faulty Hub 5 then as this one adamantly refuses to download maps from the Tom Tom server with MyDrive Connect (after it corrupted my Europe map and rendered the unit useless yesterday). Are you sure that when you did Tom Tom updates you were using MyDrive Connect as opposed to Tom Tom Home, which was an older application, which worked much more reliably and was more flexible - presumably that's why they scrapped it. LOL
When MyDrive Connect tries to download, the time left message goes from several hours to just 1 second left within a few seconds, and the time stays at 1 second, with no download activity.
I have clean reinstalled the MyDrive app, reset the Sat Nav, re-formatted the micro SD card, tried port forwarding, tried Windows 10 allow application firewall rules. Nothing works. I NEVER had this problem with my Hub 3. It worked every time with the same laptop and Sat Nav device.
A trip to a friend's house yesterday with my laptop and it downloads fine; although the files still fail to install on the Sat Nav. I am currently trying a different PC, or it will be a call to Tom Tom support tomorrow.
You may be right about the corrupt download, as even with the files I successfully downloaded from a friend's Virgin Cable modem, they fail to install and the Tom Tom is still bricked. I will be raising the matter with Tom Tom support this morning.
I am not the only person who is having the problem, given by the responses to my post on their Forum:
Without setting up port forwarding for the TCP ports that the TomTom MyDrive application uses, the Hub 5's firewall blocks packets and the TomTom map downloads fail. With port forwarding enabled for all ports the application uses, the map downloads work reliably.
I have now written a guide on my blog which explains exactly how to set up port forwarding for the TomTom MyDrive application. *Edited by Mod*
it's the link to your blog that is the problem not the information so just copy and paste your solution
