Alex05
Newbie
Message 1 of 7
BT Home Hub 5 on TalkTalk
Before I was a BT Infinity customer with a BT Home Hub 3 and as soon as the BT Home Hub 5 was made available I bought it and yes it was better than the BT Home Hub 3 (returned to BT as per request received from BT), however with my disappointment I noticed that the surely not cheap BT Home Hub 5 is not working with the TalkTalk fibre service and I suspect it is locked to BT service. Please advise how it can be used with TalkTalk
6 REPLIES 6
Jonkarra
Expert
Message 2 of 7
Re: BT Home Hub 5 on TalkTalk
Its locked to BT and there is no way to unlock it.
Message 3 of 7
correct it is locked to BT and not usable with other ISP's
Distinguished Guru
Message 4 of 7
The Hub3 was locked to BT as well.  If you paid for the Hub5, you didn't actually have to return the Hub3 if you didn't ewant to.
Guru
Message 5 of 7
Just received an email about the Home Hub 4r. Seems this one is not locked to BT!
http://www.shop.bt.com/products/bt-home-hub-4r-94XH.html?utm_source=retention%20email&utm_medium=ema...
jimbof
Message 6 of 7
What aspect of the Home Hub 5 is locked to BT?  I am using one with PlusNet just fine.
astar27
Expert
Message 7 of 7
That's slightly different. It works on BT residential, BT business and plus net as it's a subsidiary of BT group.
