Message 11 of 17
Re: BT Home Hub 6 Blocking Samba File Sharing over LAN
What app are you using?
Message 12 of 17
I use an Android App called Solid Explorer, but there are several alternatives. Investigate the Play Store for SMB / Samba access apps.
Message 13 of 17
Just downloaded and tried Andsmb as a test, that works fine on my Pixel6
Message 14 of 17
@WhyDidISignUpToThem@ try Solid Explorer as recommended by@Oakington_Mike @ it works just fine and has a good UI.
You need to login to the hub as guest and set SMB 1 in advanced settings.
Message 15 of 17
I still can't get beyond the, app seeing the hub.
Please help me with the, settings. Thank you.
Message 16 of 17
For which app?
For Solid Explorer, click on the + symbol > new cloud connection > LAN/SMB > select your hub > guest > set advanced to yes > select smb1 > connect
Message 17 of 17
Thank you, licquorice.
Brilliant.
All working now,
