Solved! Go to Solution.
Yes, the HH6 is compatable. It was the ECI cabs that the problem.
You don't expect BT to make it that easy? Youll know when it happens usually after 10 - 14 days.
Possibly for you it's happened.
And are the HH5A/Bs G.INP compatible too? Upstream and Downstream?
G.Inp upstream isn't active on any Openreach cabinet. The hubs are compatible if ever done though.
Upstream G.INP can be switched on by DLM on individual Huawei lines but is rarely done so and even then, it's normally temporary.
ECI cabinets don't support upstream G.INP unless something has changed
