Hopefully this is the correct place to post.
Devices in the house have started not connecting to my BTHH6 wifi? This is not a range issue as device in the same room will full strength occasionally have issues. Ethernet connections are rock solid.
I've changed channels and done a factory reset but the problem persists intermittently.
Of interest now when i turn the HH off it does a full reset (passwords and HH name going back to defaults)without me pressing the reset button(. Its also very hot to the touch.
Grateful for any suggestion as I am struggling to find a way to interact with BT direct?
Peter
have you split the wireless networks which is possible on HH6 but not SH2
it is not difficult to interact with BT just phone 150
If it keeps resetting to factory default, then its faulty and needs replacing.
have you turned of smart setup
have you split the networks
as @Keith_Beddoe posted if hub keeps resetting back to factory setting then phone 150 and ask for replacement
