pittnuma
Message 1 of 1
BT Home Hub DNS
Hi,
Starting to get fedup been using Dynamic DNS to update my IP on DTDNS, it's been working fine for a long time (last 2 years), however recently I notice the hub is not passing the IP down or is passing the wrong IP to DtDNS.
The Hub states the DynamicDNS has a connection, if you click refresh it states it has updated correctly. However when I logon to DtDNS I note the IP has not updated, even if I give it 24hrs. If I manually change my IP it resolves the hostname correctly until my IP changes on the hub again and I'm back to square 1.
I have reset, factory reset. Checked all my login details for the Dynamic DNS I have put a 21 day lease on the IP so it is not doing it everyday. It is a Hub 4 by the way.
Really getting fedup with this.
Any ideas? Thankfully it is nearly time for me to renew so if I cannot fix it I will move as I rely on my FTP server being able to resolve through via the hostname.
Hoping somebody knows what to do.
