Since last night the Home Hub 5 has started dropping connection the first time the hub started flashing green and then was followed by a orange light, once the blue light came back on I checked the hub stats and it still showed 13 days connection time. Then this morning it dropped again with the open RG event, right now it doesnt seem to have effected the speed but I will update this thread if it keeps dropping.
00:44:50, 01 Oct. (1202898.740000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:44:48, 01 Oct. (1202896.520000) WAN operating mode is VDSL
00:44:48, 01 Oct. (1202896.520000) Last WAN operating mode was VDSL
00:44:46, 01 Oct. (1202894.930000) PPP IPCP Receive Configuration ACK
00:44:46, 01 Oct. (1202894.810000) PPP IPCP Send Configuration Request
00:44:46, 01 Oct. (1202894.810000) PPP IPCP Receive Configuration NAK
00:44:46, 01 Oct. (1202894.690000) PPP IPCP Send Configuration ACK
00:44:46, 01 Oct. (1202894.690000) PPP IPCP Receive Configuration Request
00:44:46, 01 Oct. (1202894.590000) PPP IPCP Send Configuration Request
00:44:45, 01 Oct. (1202893.190000) PPPoE is up - Down Rate=79906000Kbps, Up Rate=19999000Kbps; SNR Margin Down=9.2dB, Up=15.3dB
00:44:45, 01 Oct. (1202893.180000) CHAP authentication successful
00:44:44, 01 Oct. (1202892.970000) CHAP Receive Challenge
00:44:44, 01 Oct. (1202892.970000) Starting CHAP authentication with peer
00:44:44, 01 Oct. (1202892.970000) PPP LCP Receive Configuration ACK
00:44:44, 01 Oct. (1202892.960000) PPP LCP Send Configuration Request
00:44:44, 01 Oct. (1202892.960000) PPP LCP Receive Configuration Reject
00:44:44, 01 Oct. (1202892.960000) PPP LCP Send Configuration ACK
00:44:44, 01 Oct. (1202892.960000) PPP LCP Receive Configuration Request
00:44:42, 01 Oct. (1202890.350000) CWMP: session closed due to error: No response
00:44:42, 01 Oct. (1202890.330000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
00:44:42, 01 Oct. (1202890.330000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:44:11, 01 Oct. (1202859.880000) CWMP: session closed due to error: No response
00:44:11, 01 Oct. (1202859.860000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
00:44:11, 01 Oct. (1202859.850000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
00:44:11, 01 Oct. (1202859.410000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
00:44:10, 01 Oct. (1202858.690000) PPPoE is down after 20045 minutes uptime [Disconnected]
00:44:08, 01 Oct. (1202856.320000) PPP LCP Send Termination Request [Peer not responding]
02:37:06, 01 Oct. (1209634.520000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
02:37:05, 01 Oct. (1209634.090000) CWMP: Initializing transaction for event code 2 PERIODIC
02:12:13, 01 Oct. (1208141.220000) CWMP: session completed successfully
02:12:12, 01 Oct. (1208140.900000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
02:12:05, 01 Oct. (1208133.820000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
02:12:05, 01 Oct. (1208133.810000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
02:12:03, 01 Oct. (1208131.610000) WAN operating mode is VDSL
02:12:03, 01 Oct. (1208131.610000) Last WAN operating mode was VDSL
02:12:01, 01 Oct. (1208130.040000) PPP IPCP Receive Configuration ACK
02:12:01, 01 Oct. (1208130.030000) PPP IPCP Send Configuration Request
02:12:01, 01 Oct. (1208130.030000) PPP IPCP Receive Configuration NAK
02:12:01, 01 Oct. (1208130.020000) PPP IPCP Send Configuration ACK
02:12:01, 01 Oct. (1208130.020000) PPP IPCP Receive Configuration Request
02:12:01, 01 Oct. (1208130.020000) PPP IPCP Send Configuration Request
02:12:00, 01 Oct. (1208128.670000) PPPoE is up - Down Rate=79906000Kbps, Up Rate=19999000Kbps; SNR Margin Down=9.2dB, Up=15.3dB
02:12:00, 01 Oct. (1208128.660000) CHAP authentication successful
02:11:59, 01 Oct. (1208128.000000) CHAP Receive Challenge
02:11:59, 01 Oct. (1208128.000000) Starting CHAP authentication with peer
02:11:59, 01 Oct. (1208127.990000) PPP LCP Receive Configuration ACK
02:11:59, 01 Oct. (1208127.980000) PPP LCP Send Configuration Request
02:11:59, 01 Oct. (1208127.980000) PPP LCP Receive Configuration Reject
02:11:59, 01 Oct. (1208127.900000) PPP LCP Send Configuration ACK
02:11:59, 01 Oct. (1208127.900000) PPP LCP Receive Configuration Request
02:11:59, 01 Oct. (1208127.900000) PPP LCP Send Configuration Request
02:11:09, 01 Oct. (1208077.780000) CWMP: session closed due to error: No response
02:11:09, 01 Oct. (1208077.750000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
02:11:09, 01 Oct. (1208077.750000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
02:10:39, 01 Oct. (1208047.310000) CWMP: session closed due to error: No response
02:10:39, 01 Oct. (1208047.290000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
02:10:39, 01 Oct. (1208047.290000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
02:10:38, 01 Oct. (1208046.850000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
02:10:38, 01 Oct. (1208046.130000) PPPoE is down after 85 minutes uptime [Disconnected]
02:10:35, 01 Oct. (1208043.780000) PPP LCP Send Termination Request [Peer not responding]
10:31:54, 01 Oct. ( 44.290000) 2.4 GHz Wireless: Rescan, Reason: 'Power-up'
10:31:54, 01 Oct. ( 44.290000) Wire Lan Port 4 up
10:31:54, 01 Oct. ( 44.290000) Wire Lan Port 2 up
10:31:53, 01 Oct. ( 43.360000) WAN Auto-sensing running.
10:31:48, 01 Oct. ( 37.880000) System up, firmware version: 4.7.5.1.83.8.204.1.11 (Type A)
10:31:39, 01 Oct. ( 29.030000) WPA2 mode selected
10:31:39, 01 Oct. ( 29.030000) WPS enabled
10:31:36, 01 Oct. ( 25.990000) WPA2 mode selected
10:31:36, 01 Oct. ( 25.990000) WPS enabled
10:31:26, 01 Oct. ( 15.870000) System start
10:30:55, 01 Oct. (1238063.940000) PPP LCP Send Termination Request [User request]
10:30:53, 01 Oct. (1238061.980000) The system is going DOWN for reboot.
10:30:53, 01 Oct. (1238061.980000) OpenRG is going for reboot by IPC command
10:30:48, 01 Oct. (1238056.980000) OpenRG will go down for reboot in 5 seconds
Stat Page:
1. Product name: | BT Home Hub |
2. Serial number: | +076272+NQ33595271 |
3. Firmware version: | Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 23/06/15 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 0 days, 01:07:37 |
6. Data rate: | 19999 / 79906 |
7. Maximum data rate: | 28299 / 94257 |
8. Noise margin: | 14.9 / 9.6 |
9. Line attenuation: | 16.7 / 14.8 |
10. Signal attenuation: | 16.7 / 14.8 |
11. Data sent/received: | 13.2 MB / 180.0 MB |
12. Broadband username: | bthomehub@btbroadband.com |
13. BT Wi-fi: | No |
14. 2.4 GHz Wireless network/SSID: | BTHub5-3XCF |
15. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
16. 2.4 GHz Wireless security: | WPA2 |
17. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
18. 5 GHz Wireless network/SSID: | BTHub5-3XCF5G |
19. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
20. 5 GHz Wireless security: | WPA2 |
21. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
22. Firewall: | Default |
23. MAC Address: | |
24. Modulation: | G.993.2 Annex B |
25. Software variant: | AA |
26. Boot loader: | 1.0.0 |
I would monitor and as you say post back if it continues. My hh5a resets like clockwork every 14 days but as long as speed and noise margin come back the same it is more annoying than a problem
have you check quiet line test dial 17070 option 2 should be quiet and best with corded phone
Just did a quiet line test and it seemed fine (havent got a corded phone though so was using a wireless handset)
Will keep you all updated with how it performs throughout the day 🙂
Don't expect any ISP supplied equipment to be anything other than the ISP has requested from the manufacturer. They will then install their own firmware on it locking it down to thier requirements
If BT require that it updates every 14 days then that is what BT's firmware will tell it to do
Having had it checked by mods it is not the hub firmware but the DLM which is resetting my hub every 14 days - still unable to find why but as just annoying and not a pronlem I have not pusued the matter
@imjolly wrote:
@pippincp wrote:Don't expect any ISP supplied equipment to be anything other than the ISP has requested from the manufacturer. They will then install their own firmware on it locking it down to thier requirements
That said have you tried a 3rd party router/combo. Is it the hub firmware that requests the reset or DLM? I know the mods have told you it is DLM but it's funny no-one using 3rd party equipment have reported this?
as someone has already posted why should I if at present my HH5a is working just fine with a slight annoyance that it resets every 14 days the DLM will not have the same control over a 3rd party router as it does to a home grown HH5A
@pippincp are you suggesting the mods are just telling me a story which is not correct?
@imjolly wrote:as someone has already posted why should I if at present my HH5a is working just fine with a slight annoyance that it resets every 14 days the DLM will not have the same control over a 3rd party router as it does to a home grown HH5A
No, what I am saying is that it could be a firmware glitch that no-one is aware of and expect it to be normal behaviour.
but what I said was mod had it investigated including by Network Team. If it was a firmware problem then there would be far more posts than just the 2 I remember bearing in mind the number of customers whoi have and use a HH5a
