RyanBrooks
Message 1 of 9
BT Home Hub Manager problems.
Hello BT,
I am currently having problems connecting to the BT Home Hub Manager.
I have tried the following:
These all end up with the connection timing out because it's taking too long to respond. All other websites are working fine and well for me. I've also tried this on Mozilla Firefox, Internet Explorer and Safari web browsers.
Also, I have asked a few other people in my area I know who are with BT and they are not getting the same problem as me.
Kind regards,
Ryan.
8 REPLIES 8
champ1970
Message 2 of 9
Re: BT Home Hub Manager problems.
try.... 192.168.1.254..............
RyanBrooks
Message 3 of 9
Oops, my bad. I did try 192.168.1.254.
Sorry for the mishap of spelling that IP wrong. I'll edit the post now.
wedd1ng528
Message 4 of 9
Have you tried, using a command prompt, to ping your router on 192.168.1.254?
wedding
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
jjgraphics
Recognised Expert
Message 5 of 9
The HH internals sometimes get in a tangle, and if you happen to have made any changes to the various settings, that can sometimes compound matters.
Try doing a Factory Re-set (paperclip into small hole at side of hub) and see if that resolves matters. Doing a re-set will remove any settings that you may have applied, so be prepared to make the settings again if necessary. The re-set also restores the default wireless settings which are displayed on a label on the back.
If that does not solve it, you may need to ask for a replacement HH.
DS
Distinguished Guru
Message 6 of 9
You could try to access the hub manager this way...
Go to this link to find your current IP address - http://www.whatsmyip.org/
Then input your IP address in to your browser.
You'll then need to input your hubs password.
Hopefully voila?
-+-No longer a forum member-+-
john46
Message 7 of 9
Moved:
Annraoi
Message 8 of 9
The solution to this problem is to carefully put the following into the address bar as follows:
http://192.168.1.254
imjolly
Message 9 of 9
This thread is over 2 years old
