osk
Message 1 of 33
BT Home Hub keeps cutting off
Hi, my BT home hub keeps disconnecting the internet several times a day and it's becoming really annoying. Is there anything I could do?
32 REPLIES 32
Message 2 of 33
Re: BT Home Hub keeps cutting off
Hi Welcome to the forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 33
osk
Message 4 of 33
DSL Connection
Link Information
Uptime:0 days, 0:48:32
Modulation:G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:448 / 2,560
Data Transferred (Sent/Received) [MB/MB]:4.61 / 16.01
Output Power (Up/Down) [dBm]:12.0 / 16.5
Line Attenuation (Up/Down) [dB]:30.0 / 50.0
SN Margin (Up/Down) [dB]:23.0 / 6.5
Vendor ID (Local/Remote):TMMB / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):0 / 19,005
CRC Errors (Up/Down):0 / 20
HEC Errors (Up/Down):0 / 16
Line Profile:Interleaved
I am using BT Home Hub 1.5
Message 5 of 33
Does it restart itself without you touching it?
What does the event log show?
osk
Message 6 of 33
How do I find the event log?
No the only way to "reset" the internet connection is by switching off the hub and switching it on again, although this method is declining as it is becoming less effective, not to mention time wasting.
Also sometimes when the phone rings I notice the connection is cut off aswell, not sure if that helps.
When the internet is cut off, the internet logo/icon on the hub is not lit up like it's supposed to.
Message 7 of 33
It could be a faulty hub.
As shown in my document, please can you connect things up as shown below.
Testing from "test" socket
I am not sure where the event log is, on the HH1.5, but it may be on this link.
http://192.168.1.254/cgi/b/events/?ce=1&be=0&l0=3&l1=-1
osk
Message 8 of 33
Okay, this is the event log.
Recorded Events
  Time Message
Info Dec 30 14:57:42LOGIN User tried to login on [HTTP] (from 192.168.1.67)
Info Dec 30 14:57:42LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
Info Dec 30 14:57:37LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
Info Dec 30 14:57:37LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
Info Dec 30 14:52:41LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
Info Dec 30 14:21:25SNTP Synchronised to server: 213.123.26.170
Error Dec 30 14:21:25SNTP Systemtime update: time setting 00:03:52 > new time setting: 14:21:25
Info Jan 1 00:02:43CONFIGURATION saved by TR69
Info Jan 1 00:01:39FIREWALL event (1 of 1): disabled rules
Error Jan 1 00:01:38FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 93.191.192.1 Dst ip: 86.131.155.224 Type: Echo Reply Code: 0
Warning Jan 1 00:01:36PPP link up (Internet) [86.131.155.224]
Info Jan 1 00:01:34PPP CHAP Chap receive success : authentication ok
Info Jan 1 00:01:34PPP CHAP Receive challenge (rhost = ESR3.Edinburgh5)
Info Jan 1 00:01:23xDSL linestate up (downstream: 2560 kbit/s, upstream: 448 kbit/s; output Power Down: 16.5 dBm, Up: 12.0 dBm; line Attenuation Down: 50.0 dB, Up: 30.0 dB; snr Margin Down: 6.5 dB, Up: 23.0 dB)
Warning Jan 1 00:01:04DHCS server up
Info Jan 1 00:01:03FIREWALL level changed to Disabled.
Info Jan 1 00:00:58WIRELESS automatic channel selection done (channel = 7)
Info Jan 1 00:00:50FIREWALL event (1 of 1): enabled rules
Info Jan 1 00:00:41WIRELESS interface turned on.
Warning Jan 1 00:00:29KERNEL Warm restart
Info Jan 1 00:00:28FIREWALL event (1 of 1): modified rules
Info Jan 1 00:00:28FIREWALL event (1 of 1): created rules
Also, the test socket must be from the master socket correct? Because the hub is actually connected to the socket from my room.
Message 9 of 33
This is what I was looking for.
Warning  Jan 1 00:00:29 KERNEL Warm restart
Did it restart on its own, or did you you restart it?
The test socket would be located at your master socket. You need to test from there, to eliminate any internal wiring issues.
osk
Message 10 of 33
No I manually restarted the Home Hub, I have now plugged it to the test socket. What do I do now?
