Iknowyourusername
Message 1 of 3
BT Home Hub or LINKSYS E4200
Hello,
I'm seeing a lot of messages from people saying the BT Home Hub 3.0 is not very good and are changing to the
LINKSYS E4200 which looks like this:
This I think supports Fibre Broadband do you suggests I should get this when I get Infinity, will it work which BT?
2 REPLIES 2
jamjar62
Expert
Message 2 of 3
Re: BT Home Hub or LINKSYS E4200
I would try the Home Hub 3 first before you spend money as i was also going to buy a new router before trying it ,but i think with a few tweaks i will be okay 🙂
JamJar62
roetetoet
Message 3 of 3
I am really happy with my home hub. Does everything it needs to do and I see no reason to get a other solution beside that you can get combined router/modems like the draytek vigor.
I would test first and see if it does what you need it to do
