Message 1 of 7
BT Home hub 2 on PC
Hello all,
I have just installed the BT Home hub 2, however my wired connection to the PC does not work. The connection just times out and I have tried using the windows solutions to fix but it says there is the default gateway is not available and just disconnects if I load a webpage. The PC reads the packets etc but I cannot load any webpages unless the Wifi is on (Motherboard has a wifi connection) I use Windows 10.
If I use my old BT Home hub 5, it is connected to a Huawei Model: Echolife HG612 BT openreach box on my desk. I use the WAN port to connect the hub
Wired and Wifi work no problem at all on the hub 5
Does anyone know a solution I could try?
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: BT Home hub 2 on PC
It sounds like your wired network adapter is set for static and the IP address set is already in use (IP Clash)
Message 4 of 7
sorry but you are connecting the SH2 direct to the master socket and missing out the modem as modem is no longer required for FTTC
Message 5 of 7
Thanks yes thats what I thought
Is the Smart Hub 5 with the Modem the best thing to continue using?
Not sure what I can do with the Smart hub 2
Message 6 of 7
I have already done this and unfortunatley it didnt work
Message 7 of 7
I have switched off the smart set up and restarted the smart hub 2 and its only connected by a wired connection
wifi is off
thanks so much Keith
