Message 1 of 5
BT Home hub not connected message
We use my wife's XP sp3 laptop wirelessly at home, but when we use it away from home on a 'paid for' wireless providers network (as no BTFon is avaliable at that location), we occasionally get the BT Home hub not connected message come up in an IE page. How can it be turned off, there is no solution in BT FAQs?
Regards
4 REPLIES 4
Message 2 of 5
Re: BT Home hub not connected message
Hi, Sounds more like a something to do with the Window's O.S so I can understand why there is nothing in the BT FAQ's, however you could try clearing the cache on I.E
Raid
Message 3 of 5
Thanks for that. Naturally I cannot test this until we are in that environment, but it seems logical.
Regards
Message 4 of 5
Just for good measure, I would install another web browser while you still have internet access. Then if you have the same problem, try the other web browser and see if that works.
I noticed that you said it says that the Hub is switched off. This is the message that appears when there is no internet connection at all.
Maybe the WiFi had dropped and there was no signal for a small period of time, then when it went to go to the 'page cannot be displayed' screen it redirected you to the 'hub is switched off' message because it had been cached previously.
Message 5 of 5
