Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
There is some help here
Hi Welcome to the forums
Here are some help pages done by CL Keith http://forumhelp.dyndns.org/speed/Speed.html
also post your full hub stats by entering 192.168.1.254 into your web browser address bar and navigate to adsl or use a-z, if netgear enter 192.168.0.1
Can you also post the full results from BT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This link may also help http://bt.custhelp.com/app/answers/detail/a_id/7609/c/346,407,411
This is a customer to customer self help forum the only BT presence here are the forum moderators
Line state | Connected |
Connection time | 0 days, 0:04:11 |
Downstream | 11,145 Kbps |
Upstream | 908 Kbps |
VPI/VCI | 0/38 |
Type | PPPoA |
Modulation | ITU-T G.992.5 |
Latency type | Interleaved |
Noise margin (Down/Up) | 2.8 dB / 6.0 dB |
Line attenuation (Down/Up) | 38.0 dB / 19.6 dB |
Output power (Down/Up) | 0.0 dBm / 12.3 dBm |
Loss of Framing (Local) | 22 |
Loss of Signal (Local) | 2 |
Loss of Power (Local) | 0 |
FEC Errors (Down/Up) | 154975 / 0 |
CRC Errors (Down/Up) | 61 / N/A |
HEC Errors (Down/Up) | N/A / 291 |
Error Seconds (Local) | 1 |
1. Best Effort Test: -provides background information.
Download Speed | |
9.2 Mbps |
0 Mbps | 21 Mbps Max Achievable Speed |
Download speed For your connection, the acceptable range of speeds IP Profile for your line is - 9.83 Mbps |
2. Upstream Test: -provides background information.
Upload Speed | |
0.71 Mbps |
0 Mbps | 0.83 Mbps Max Achievable Speed |
Upload speed Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps |
The Quiet test came back fine (nothing out of the ordinary) and I am currently using the master socket (Not the test one)
Any Suggestions?
ADSL line status
Connection time | 0 days, 0:24:06 |
VPI/VCI | 0/38 |
Type | PPPoA |
Noise margin (Down/Up) | 2.6 dB / 6.0 dB |
FEC Errors (Down/Up) | 1220916 / 4294967261 |
CRC Errors (Down/Up) | 77 / N/A |
HEC Errors (Down/Up) | N/A / 0 |
Error Seconds (Local) | 2563 |
You can ignore FEC errors, they are corrected errors, and do not affect your broadband speed, and are quite normal.
Thanks for the response but do you know the problem with my line?? Is it the router? or what?? This stability issue is really annoying. Hopefully you can understand my frustration
Had yet another crash so I have been monitoring it and the CRC Errors are increasing - Is that any good?
ADSL line status
Connection time | 0 days, 0:30:28 |
Downstream | 10,949 Kbps |
Upstream | 904 Kbps |
VPI/VCI | 0/38 |
Type | PPPoA |
Noise margin (Down/Up) | 2.7 dB / 6.3 dB |
Output power (Down/Up) | 0.0 dBm / 12.1 dBm |
Loss of Framing (Local) | 33 |
Loss of Signal (Local) | 3 |
FEC Errors (Down/Up) | 6059124 / 4294967264 |
CRC Errors (Down/Up) | 1871 / N/A |
Error Seconds (Local) | 10 |
First of all thanks for your help!!
Just a couple of questions regarding the solution
How long will it take for the noise to increase and will it stay that way??
Also When it says "simply disconnect the adsl input for about 20 seconds, then plug it back in." Is that the input into the router or at the master socket??
Thanks again for your help!
