john46
Message 11 of 37
Re: BT HomeHub 2 broadband connection drops
hi it should increase immediately as to which end of the cable to disconnect you can use either end it should stay until the line is seen stable and may drop again if it does and the problem re appears then we can get you intouch with the forum mods and get them to get a fixed noise margin set
Shadowjk
Message 12 of 37
Okay it disconnected again so I followed what it said and this is now the results - I am going to leave it for the night and check on it in the morning
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:01:09
Downstream10,903 Kbps
Upstream903 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.4 dB / 6.1 dB
Line attenuation (Down/Up)38.0 dB / 19.6 dB
Output power (Down/Up)0.0 dBm / 12.3 dBm
Loss of Framing (Local)66
Loss of Signal (Local)6
Loss of Power (Local)0
FEC Errors (Down/Up)11255 / 0
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 27
Error Seconds (Local)6172
Thanks for all your help
john46
Message 13 of 37
The down noise margin should be 6db just keep trying
Keith_Beddoe
Message 14 of 37
There are a lot of error seconds showing, which is probably due to noise being picked up.
Are you connected to the "test" socket at the moment?
Shadowjk
Message 15 of 37
No I am on the normal Master socket
Just another Drop out 😞 (Never gotton passed 12 hours)
ADSL line status
Line stateConnected
Connection time0 days, 0:04:37
Downstream11,363 Kbps
Upstream906 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)3.6 dB / 6.1 dB
Loss of Framing (Local)0
Loss of Signal (Local)0
FEC Errors (Down/Up)151921 / 4294967264
CRC Errors (Down/Up)19 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)10
john46
Message 16 of 37
can you try connecting to the test socket and leave it there for a few days
Shadowjk
Message 17 of 37
Okay just placed it into the test socket
New results
ADSL line status
Line stateConnected
Connection time0 days, 0:00:41
Downstream11,446 Kbps
Upstream912 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Loss of Framing (Local)46
Loss of Signal (Local)4
FEC Errors (Down/Up)11996 / 0
HEC Errors (Down/Up)N/A / 29
Error Seconds (Local)28
Shadowjk
Message 18 of 37
So is my problem the noise then?? If so How can I fix this because I have tried the previous solution and it hasn't changed it at all 😞
Thanks again
Keith_Beddoe
Message 19 of 37
Well 46 losses of framing and 28 errored seconds in just 41 seconds, assuming that you restarted the home hub when you moved it to the test socket, is not very good, and would indicate some form of external interference being picked up on your phone line.
Shadowjk
Message 20 of 37
I hadn't Smiley Embarassed But have now
ADSL line status
Line stateConnected
Connection time0 days, 0:00:59
Downstream11,393 Kbps
Upstream902 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)3.5 dB / 6.0 dB
Output power (Down/Up)0.0 dBm / 12.1 dBm
FEC Errors (Down/Up)21805 / 0
HEC Errors (Down/Up)N/A / 10
Error Seconds (Local)0
I shall leave it and let you know again when an outage occurs
