Shadowjk
Message 21 of 37
Re: BT HomeHub 2 broadband connection drops
Just dropped out again after 20 mins Smiley Frustrated (On Test Socket) - I haven't yet restarted my hub
Line stateConnected
Connection time0 days, 0:00:36
Downstream11,424 Kbps
Upstream900 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.5 dB / 6.0 dB
Line attenuation (Down/Up)38.0 dB / 19.6 dB
Output power (Down/Up)0.0 dBm / 12.0 dBm
Loss of Framing (Local)24
Loss of Signal (Local)2
Loss of Power (Local)0
FEC Errors (Down/Up)13133 / 0
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 8
Error Seconds (Local)9
john46
Message 22 of 37
it looks like the low noise margin is causing a possible problem have a look at this link and try the tips that are suggested http://forumhelp.dyndns.org/speed/noisemargin.html
Shadowjk
Message 23 of 37
I have already tried the tips in that link however the noise margin does not change at all... Can they not put a cap on it??
john46
Message 24 of 37
hi yes the mods can if you ask them put a fixed noise margin on a line for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
Shadowjk
Message 25 of 37
Just another drop out - If anything this has got worse 😧 , I have now switched back to master socket as the test one is no different
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:00:52
Downstream11,442 Kbps
Upstream906 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)3.4 dB / 6.1 dB
Output power (Down/Up)0.0 dBm / 12.4 dBm
Loss of Framing (Local)35
Loss of Signal (Local)3
FEC Errors (Down/Up)17830 / 0
HEC Errors (Down/Up)N/A / 192
Error Seconds (Local)19
john46
Message 26 of 37
Ok use the link i have posted but make sure you ask them to fix the noise margin as a simple reset will not help you
Keith_Beddoe
Message 27 of 37
I don`t think its a noise margin problem, as there are no CRC events.
The error seconds count and the loss of framing indicates a serious problem, which is not going to be fixed with an increase in the target SNR.
Framing errors are a real issue, and could be due to a faulty hub, or exchange equipment.
Normally I would expect to see lots of CRC events before loss of framing occurs. Losses of framing only occur when you get very high CRC events first.
Hopefully one of the BT Care Team can get the problem investigated.
Do you have an alternative router you could try, just to eliminate that possibility?
Shadowjk
Message 28 of 37
I might have a netgear which I got for my previous ISP but I am not sure - will have a look
Will I need any details for setting it up with a new router??
Also if it is the exchange equipment I take it I will have no control over that and have to get an engineer out??
Keith_Beddoe
Message 29 of 37
I think John46 uses a Netgear, so I am sure he will help.
If he does not reply, then I will try and help.
Keith_Beddoe
Message 30 of 37
If you do find your Netgear one, then let me know. Thanks.
