imjolly
Message 11 of 19
Re: BT HomeHub3 Router disconnecting and reconnecting randomly
 From your description and as you are using test socket it sounds like you have a high resistance fault so you need to phone 151     And report a phone fault with no mention of broadband. http://www.kitz.co.uk/adsl/connectionprobs.htm
Noel457
Message 12 of 19
Thank you so much for your help. Will this mean that I will have to get an engineer round?
Noel457
Message 13 of 19
Thanks for the help. I called 151 and they did the checks but it showed there was no problems with the line so we will get an engineer round when your offices are open. Or if you could arrange an engineer to come round, that would be even better.
imjolly
Message 14 of 19
I am it a customer like you and only BT employees are the forum mods. Just phone 151 again tomorrow refer to forum do high resistance fault. CS have a habit of not phoning back
Noel457
Message 15 of 19
Sorry. I mistook your for one due to your badge next to your name. Well thank you very much for taking the time out and helping me out.
Noel457
Message 16 of 19
Thanks so much for your help once again. Just to update, we got an engineer round and straight away he knew something was up especially as it was a similar problem to other houses under our telephone exchange. It was quite a simple problem as when they upgraded the broadband at the exchange, the noise margin was set too high which caused the internet to drop out as it was being overworked. The crackling phone line was also because of this. Not the best explanation of what is going on but just wanted to keep you updated.
imjolly
Message 17 of 19
as long as engineer managed to solve your problem
thanks for update
Keith_Beddoe
Message 18 of 19
Noise margin was probably set too low at 3dB instead of 6dB.
Noel457
Message 19 of 19
Yes it was too low. That is correct. Thank you
