Chris_896
Newbie
Message 1 of 4
BT Homehub port forwarding - Conflicts?
I am trying to set up an application for a minecraft server. I need to forward ports and I create the application for the Minecraft server with ports 25565 and when I try to actually apply it, it says:
ports setting conflict
This application ports setting conflict with others, Please correct it and try again.
I dont see how there are any conflicts? I dont have any other applications set up on my router?
3 REPLIES 3
notoriousdbp
Recognised Expert
Message 2 of 4
Re: BT Homehub port forwarding - Conflicts?
Same thing happens when you try to add Xbox Live - nobody knows why.  Basically a full reset seems to be the only fix and even then you have to be quick when setting up port forwarding otherwise the conflicts issue happens.
---Remember to mark as 'solved' and give stars when you like a post---
hammond0207
Newbie
Message 3 of 4
but how do you full restore
notoriousdbp
Recognised Expert
Message 4 of 4
use a pen in the 'Reset to Defaults' hole in the side of the hub and all original settings will be restored
