foxyjay
Message 1 of 2
BT Homehub3........can I request a newer unit as I can't access WPS!
Pretty much as per the title.
I have bought the first item (a printer) with WPS setup and low-and-behold - I find out that the HH3 doesn't support it!
Can I request a newer BTHH from BT at no cost?
MTIA!
1 REPLY 1
imjolly
Message 2 of 2
Re: BT Homehub3........can I request a newer unit as I can't access WPS!
Not for the reason you describe - you don't need wps to be able to connect your printer just set up manually
you could if you are out of contract renew your contract and ask for new hub at same time
