Spidermike
Message 1 of 2
BT Homeplug and Devolo - compatible
I have BT infinity with Homeplug 500 going from the modem to the smart TV.
I have an unused Devolo dLan 200 AV Wireless N homeplug lying around and was wanting ito know if it is compatible - can I use it as a 'wired' conneciton for my computer in the attic? I realise there may be a hit on connecton speed - I do stram some things to the computer (films or sport) but I don't do online gaming so if there is a hit on the speed it may not be an issue.
I know I could just try it but it will invovle a bit of reorganisation will be needed and I thought I would get some thoughts before committing to that.
Thank you for your help.
1 REPLY 1
imjolly
Message 2 of 2
Re: BT Homeplug and Devolo - compatible
can you not just try to see if they will pair together first before you need to connect pc
