harryg
Message 1 of 2
BT Host 81.148.222.238 Blacklisted by CBL.
Cant send emails with 550 REJ-CON-002 as BT host at
Host namehost81-148-222-238.range81-148.btcentralplus.com
Is reported by cbl.abuseat.org as being infected thus mail transfer is blocked.
as follows:
This IP is infected with, or is NATting for a machine infected with Win32/Zbot (Microsoft).
1 REPLY 1
Message 2 of 2
Re: BT Host 81.148.222.238 Blacklisted by CBL.
Hello harryg,
Are you trying to send email directly from your network/PCs?
It's much better to use BT's smarthost for sending mail (aka SMTP)- you can use it even if you don't have a btyahoo email address. Full details of setup are here:
http://btybb.custhelp.com/app/answers/detail/a_id/6876/c/149,150/session/L3RpbWUvMTMwNzk1Nzc4OS9zaWQ...
You will find that a lot of Dynamic IP addresses are blacklisted (or getting that way). Resetting your HomeHub might fix it (it might get a new address that is not blacklisted), but I can't guarantee it.
Hope this helps,
