Message 11 of 18
Re: BT Hub 2.0 going off constantly
your noise margin at 2.8 is a bit low you may find an improvement in stability but you will lose a little speed you can contact the forum mods and request a noise margin reset this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 72 hours
They are a UK based specialist team who have a good record at getting problems solved
pauldwebber
Message 12 of 18
Stats from Today, I will try what you have suggested, Thanks     Connection information<script type="text/javascript">// createTable("normal", trClass, td1, td2); // </script>
Line stateConnected
Connection time0 days, 0:40:00
Downstream8,299 Kbps
Upstream890 Kbps
ADSL settings<script type="text/javascript">// createTable("normal", trClass, td3, td4); // </script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.0 dB / 5.3 dB
Line attenuation (Down/Up)41.5 dB / 23.4 dB
Output power (Down/Up)20.5 dBm / 12.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)2958109 / 5
CRC Errors (Down/Up)16 / N/A
HEC Errors (Down/Up)N/A / 37881
Error Seconds (Local)1
stephen252
Message 13 of 18
I have exactly the same problem - which started around about the same time last month, though I don't remember being told of any change.
ADSL line status
Line stateConnected
Connection time0 days, 0:31:58
Downstream3,639 Kbps
Upstream783 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.3
Noise margin (Down/Up)12.4 dB / 6.1 dB
Line attenuation (Down/Up)53.5 dB / 32.4 dB
Output power (Down/Up)0.0 dBm / 12.9 dBm
FEC Errors (Down/Up)0 / 4294967264
CRC Errors (Down/Up)60 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)39
Message 14 of 18
hi stephen252 could you please start your own post to save any confusion when replies are posted
stephen252
Message 15 of 18
I already have done - and as it's a related problem I don't see what difference it makes.
Message 16 of 18
the stats cause confusion particilarly as you have a high noise margin and the originator has a low margin so quite possible that it may appear same problem as it often does but in reality it is different
better sticking to your own thread - have the mods contacted you yet in your own thread?
pauldwebber
Message 17 of 18
I must admit there are a fair percentage of users on here posting about their hubs going on and off like mine,I know systems can be complex and every fault is different but still seems like too many to me.
 I had Virgin for a few years before switching to BT, its something I wish i'd never done as my Vigin internet was always on, it never dropped out, just got a bit slow in the evenings, I only swapped as my company requested we went to BT.
pauldwebber
Message 18 of 18
BT engineer out today, tested everything and stated all was ok. He has fitted a new BT Hub 2.0 type B, so lets see how its goes from here.
fingers crossed.
