Message 1 of 6
BT Hub 5 Type B
Having just upgraded to BT Infinity 2 on Monday and coming across no problems, we have today, hit a glitch.
Wi-fi is problematic and ethernet connections are not working.
However, i can see all the connected devices, just not use them all.
My MAC will not connect to the hub, neither will my sons XBOX1 and his Macbook, also the THREE home signal isnt connected.
HEEEEEEEEEEEEEEELLLLPPPPP me Smiley Mad
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: BT Hub 5 Type B
Can you post your helpdesk data from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254 or http://bthomehub.home
Please miss out any data you don't want to post
If not, I'll try again 🙂
Message 3 of 6
Re: BT Hub 5 Type B
1. Product Name: HomeHub52. Serial number: +076284+14410098503. Firmware version: v0.07.03.0814-BT (Type B) Last updated 24/2/20154. Board version: 015. VDSL uptime: 0 days, 00:10:356. Data Rate: 16177 / 576367. Maximum Data Rate: 16192 / 579388. Noise Margin: 6.2 / 6.39. Line Attenuation: 0.0 / 20.710. Signal Attenuation: 0.0 / 0.011. Data sent/received: 3.6 MB / 23.3 MB12. Broadband username: bthomehub@btbroadband.com13. BT Wi-fi: Yes14. 2.4GHz wireless network/SSID: BTHub5-MN8Q15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))16. 2.4GHz wireless security: WPA2 Only (Recommended)17. 2.4GHz wireless channel: Automatic (Smart Wireless)18. 5GHz wireless network/SSID: BTHub5-MN8Q19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))20. 5GHz wireless security: WPA2 Only (Recommended)21. 5GHz wireless channel: Automatic (Smart Wireless)22. Firewall: Default23. MAC Address: 18:83:bf:cb:8d:3024. Software variant: -25. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
Distinguished Guru
Message 4 of 6
Re: BT Hub 5 Type B
13. BT Wi-fi: Yes
Distinguished Guru
Message 5 of 6
Re: BT Hub 5 Type B
I suggest you try a factory reset of the hub
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
Message 6 of 6
Re: BT Hub 5 Type B
Have now tried several resets of the Hub 5b and still we wait for a replacement.
Really hope this solves the problem, as at present ethernet connections work occasionally and wifi to certain phones dont work !!
Can't believe that the hub went faulty after only 2 days ??
Ah well we live in hope.
anyone got any wonderful ideas Smiley Very Happy
