alex69
Message 1 of 2
BT Hub 5 and printer
My printer does not show under devices in Hub 5, wire or wireless.
I have checked every thing seems to be correct, but it does print.
1 REPLY 1
Message 2 of 2
Re: BT Hub 5 and printer
If it works, then I would not worry about it, the list of devices quite often does not show everything, this seems to be the case with all of the home hubs, even the original home hub 1, which I use.
