Message 1 of 4
BT Hub 6 Connection Issue to PC
Ive got a BT Hub 6 which I connect wirelessly to my TV, Phone, Tablet and PC
The issue I've recently recently got is that the PC won't connect to the hub each time I start it. The only way I've found is to reboot both the hub and PC, which is becoming a pain. Once connected everything is stable with no drop outs etc.
I've tried the forget the connection and then using the network password to log in but makes no difference
I'm still running Windows 8 with a Netgear USB receiver, which until recently has been fine
Any suggestions please ? Using an ethernet cable is not convenient due to the distance between the hub and PC
3 REPLIES 3
Message 2 of 4
Re: BT Hub 6 Connection Issue to PC
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
have you tried splitting the 2.4/5ghz networks and see if that helps.  I would also select channels manually instead of leaving on auto select
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
Message 3 of 4
Thanks for that - I've tested it a couple of times and seems OK
Do you have any recommendation which channels to set manually please
Message 4 of 4
The channels to select are unique to your location, nobody can recommend which to use. You need to either use a WiFi analyser app on your phone to see what channels are being used close to your location or just use trial and error.
