kncowans
Message 1 of 4
BT Hub 6 - No longer able to select ' Always use this IP address: '
Hello all
I recentlu upgraded my BT Hub 4 to the new BT Hub 6 and when I first set it up I was able to select the 'Always use this IP address:' setting for my Network Servers etc.
However, after the Firmware was upgraded a couple of days ago to the latest version (SG4B100021EC)  I am no longer able to select the 'Always use this IP address:' setting.
Just to clarify, I can select the setting and Save however the setting does not stick hence leaving me stuck with DHCP.
Now I am stuck with DHCP which has allocated different IP Addresses to my Servers which has really complicated things.
Is this a known issue and when will the next Firmware be made available?
Thanks in advance
Kevin
3 REPLIES 3
Liam_
Recognised Expert
Message 2 of 4
Re: BT Hub 6 - No longer able to select ' Always use this IP address: '
Can you not give your servers static IP addresses?
I have static IPs on all PC and both laptops here and everything works fine, new hardware like phones, tablets and visitors PCs/laptops etc still get an address from routers DHCP.
Admittedly I don't use Home hubs but can't see a problem doing this with them.
kncowans
Message 3 of 4
Hello
Thanks for the reply.
Yes, I could assign Static IP Addresses to my Servers, however there are reasons why I prefer to use the HUB to control the IP Addresses.
Also, I have just performed a Factory Reset of the Hub 6 and the setting seems to be working once again.
I just hope that Factory Resets are not going to be required after each and every Firmware Upgrade in order to get everything to work as expected again.
Kevin
licquorice
Message 4 of 4
@kncowans wrote:
Hello
Can't for the life of me think why. If you need a device to have a particular address, allocate it on the device. None of the problems of leases expiring either.
