Message 1 of 10
BT Hub 6A disgustingly slow
so, restarted broadband over 20 days ago.. and was left with capped 2 mbps download... doesnt go up nor down no matter what... HELP pls
also apparently its completely normal and its backwards with my upload
9 REPLIES 9
Message 2 of 10
Re: BT Hub 6A disgustingly slow
Any noise on you line? 17070 option 2 and best with corded phone.
Message 3 of 10
no noise
Message 4 of 10
Enter your phone number and post results remember delete number
Message 5 of 10
Message 6 of 10
funnily enough the test date is the day it went wrong
Message 7 of 10
your connection time is only 2days have you been having problems with connection dropping or manually resetting trying to get better speed or maybe bit of both
as you can see from checker your expected range is 18/11 mb so 2mb is low and probably due to unstable connection
Message 8 of 10
so how long would you say it will take to climb back up
Message 9 of 10
It could take a few weeks or in many cases a lot longer but most important connection must remain stable with no drops or resets
Message 10 of 10
How many times have you rebooted the hub?
