Message 1 of 8
BT Hub Phone - not receiving calls
Hi,
I have been using my broadband talk service recently by plugging in my landline phone into my Hub, the service has worked pefectly well but I decided I wanted a seperate phone for receiving/making BB Talk calls.
Received my new BT Hub Phone 2.1 today and it has successfully registered with my hub. However, when I call its number the hub phone doesnt ring, and I just get a bt messahe saying 'you cannot leave a message at this time'.
It does say charge for 24hrs before MAKING calls, but does this also apply for receiving calls?
tia,
Andy
7 REPLIES 7
Message 2 of 8
Re: BT Hub Phone - not receiving calls
@andydesigns wrote:
Hi,
tia,
Andy
Make sure you change the telephony settings on the hub, so that Broadband Talk rings both the rear socket, and the hub phone.
Message 3 of 8
In the BT hub manager I have set the hub phone to only receive BB Talk calls. Is this what you mean?.
Also I have noticed that although the handset says it registered, when I go into the hub manager it shows zero phones regisetered to hub.
BTW, I have the hub phone plugged into the mains in a different room to the hub, its not using the hub stand.
Message 4 of 8
Can you get higher pitched dial-tone on the hub phone? If you can, does it drop back to the normal PSTN dial-tone when you dial "5"?
Message 5 of 8
Yes I hear the high pitch tone first and the landline tone when I press 5.
I've double-checked the number in the homehub and i am definitely dialling the right one.
Message 6 of 8
Have you tried restarting the hub? I assume that the back socket still works?
Have you checked the BBT options here https://service.btbroadbandvoice.bt.com/selfcare/consumerYourAccount
Message 7 of 8
Many thanks for all your help. I restarted the hub and its now working, sorry I should have thought of that myself.
Message 8 of 8
No problem, pleased to assist you Smiley Happy
