uklee
Message 1 of 8
BT Hub Swap Box Query
Hi
I recently recived a replacement BT HH3 which arrived in a brown BT Hub Swap Box are the unit (HH3) new or reconds?
Lee
7 REPLIES 7
Aarong
Guru
Message 2 of 8
Re: BT Hub Swap Box Query
I would have a good guess that it's a recondition box, all new hubs to my knowledge would come in B.T box, having said that the hub should obviously work fine.
Any problems with the replacement?
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
uklee
Message 3 of 8
Only issue BTfon and wifi ssid was being broadcasted by the unit -I and its possible to connnect and use the internet.
I have opted out of BTfon so dont know what else to do or why Btfon is active. I dont wish to turn off the ssid becuase i need another device to see.
Lee
Aarong
Guru
Message 4 of 8
Lee
Are you sure it's your BTFON that's broadcasting and no one else's? When did you opt out of BTFON?
DS
Distinguished Guru
Message 5 of 8
Lee
It's an automatic thing that BT do:(
All new hubs 'seen' on the connection, or resetting the existing hub will always turn it back on.
You may need to go the BTWifi site, opt in and immediately out again. The BTWifi/BTWifi-with-fon should go within 2 days, but can take weeks:(
-+-No longer a forum member-+-
Aarong
Guru
Message 6 of 8
@DS wrote:
Lee
I thought it took 24 hours, maybe i'm wrong. Fortunately don't have this issue due to using my own router.
boe323
Message 7 of 8
I like btfon and wifi, it gives hackers a lesser reason to hack your wifi lol, because btfon is there to use, he heSmiley LOL
Deathtrap3000
Recognised Expert
Message 8 of 8
Brown boxes usually contain business hubs. Even the refurb hub3's come in normal boxes usually.
