Message 1 of 1
BT Hub and Wifi Disc - Can i force laptop to use Hub and not the disc???
Hi. Trying to troubleshoot a working from home issue.
IT supports states they have no end of issues with "wifi repeaters" causing issues with the VPN we use.....
I have one BT Wifi Disc setup but its mainly to provide a connection to my BT YouView box via an ethernet cable from the disc to the box.
I can see from my hub control page that the laptop is connecting via the Wifi Disc to the hub.
Is there a way i can tell the disc NOT to connect to my work laptop so the laptop is forced to connect directly to the hub??
regards
