Message 1 of 6
BT ID Help
I have recently ordered BT Infinity and a landline and it is now live and activated.
My BT ID says I have no active products and when I go to claim my Mastercard reward, it says no rewards available.
If it makes any difference, I used to be a BT Mobile customer with the same BT ID.
5 REPLIES 5
Message 2 of 6
Re: BT ID Help
Hi @CNW
It maybe worth having a chat with the ID & Password Team about the ID issues your having.
You can always make your claim for the rewards card via the Chase my rewards link
Message 3 of 6
Re: BT ID Help
Hi @CNW,
When you log in it may take you to your old BT Mobile account rather than your new account. On the top right of the page you should see an account number. You should be able to switch to your new account.
DanielS
Message 4 of 6
Re: BT ID Help
I have checked and I only have one BT account number available on my drop down box.
I have checked all the emails I recieved from BT when I placed my order and I cannot see an account number on any.
I have the order number but no account number!
Message 5 of 6
Re: BT ID Help
I have managed to sort it now.
Thanks for your help!
Message 6 of 6
Re: BT ID Help
Hi @CNW,
Thank you for posting back, I'm glad that's been sorted.
If you could post back with what you did to resolve the issue? That would be great, as this would help other users experiencing the same issue.
Cheers
PaddyB
