Message 1 of 4
BT ID's.
Hello BT Community.
I currently have 2 BT ID's
One I wish to keep as my Primary, which currently is not. The other I wish to eliminate. The one I wish to banish contains access to 2 email addresses I would like to transfer to that which I would keep as Primary.
Is it possible to configure my dilemma?
3 REPLIES 3
Message 2 of 4
Re: BT ID's.
You would need to contact the BT billing team, they deal with all things related to a BT ID
Message 3 of 4
Re: BT ID's.
Very many thanks for the direction.
Rhonny.
Message 4 of 4
Re: BT ID's.
This was the correct direction for my BT ID dilemma, and is therefore marked as accepted solution.
Again, Thank you.
