Madscot
Message 1 of 4
I finally managed to set up my BT ID with the help of a agent in the call centre, now it will not let me access it using the email and password
contacted call centre(india) and the insisted i had not set up the BT ID and he sent another activaition email. on trying this it would not accept the answer to the security question that i used last time
decided then to try the route of asking to check the email login .......this required the typing in of the bt phone number
and for some reason says it is not recognised
so to put it as it stands
1]will not accept email or password in log in
2]will not allow the use of the BT phone
3]agents on 2 occasions have tried to get me to allow them remote contol of the computer(refused).1 tried to get me to download an app which would let thim do this after i refused permisson
so how the heck do i get past this problem
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: BT ID
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
PaddyB
Moderator
Moderator
Message 3 of 4
Re: BT ID
Hi Madscot,
I'll be able to take a look at this for you. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Madscot
Message 4 of 4
Re: BT ID
thanks for the help folks, but with a fair bit of playing about ive managed to set up a new BT ID that works
