Message 1 of 20
BT INFINITY CONNECTION ISSUE
Hi guys Im actually pulling my hair out.
I have had bt broadband for 6 years and decided to upgrade to infinity in October as it has just been fitted into my area.  I was sent the newest hub and given an activation date.  My speed increased from 12mb to 14mb but a week or 2 ago it dropped to 8mb.  We arranged for an engineer to come out who said we are not connected to fibre at the exchange but are still on copper.  This is the exact message he sent me:
They will say you are connected on the system probably but by the looks of the testing and speeds I was seeing you are not connected through the fibre ports at the green cabinet (PCP in engineering terms) i don't know who you would phone, normally just your service provider which was BT, and explain that you need an engineer out to carry out the work at the PCP as your wires are only connected through copper and not fibre.
The Indian call centre are swearing blind I am connected
They have promised to call me back but havent.
I have phoned every day for the last week but they have refused to do a thing.
The engineer even called bt and told them but still nothing.
19 REPLIES 19
Message 2 of 20
Re: BT INFINITY CONNECTION ISSUE
If you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post lines 1-12
Or if you have the HH6 Smart hub post the information using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
We can then determine which service you are connected to.
Alternatively, if you still have an older hub (HH4 or earlier), you can try connecting with that. If it connects you are still on ordinary broadband.
Message 3 of 20
Can you also input your number into here http://www.dslchecker.bt.com and post the results
Message 4 of 20
Firmware version:
SG4B1000223E
Firmware updated:
06-Dec-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 8 Minutes 8 Seconds
Data rate:
1.18 kbps / 15.95 kbps
Maximum data rate:
1112 / 17364
Noise margin:
8.1 / 3.1
Line attenuation:
34
Signal attenuation:
195 / 340
VPI / VCI:
0/38
Modulation:
G_992_5_ANNEX_A
Latency type:
Fast Path
Data sent / received:
2 MB Uploaded / 14 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-Z6G5
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-Z6G5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
40:C7:29:0F:54:0F
Software variant:
Boot loader:
7.33.1
Message 5 of 20
You are still on ADSL2 standard broadband, not Infinity.
Modulation:
G_992_5_ANNEX_A
Can you also post the information Webby asked for please?
Message 6 of 20
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)22.516.11.20.8--Available----Yes--
VDSL Range B (Impacted)16.45.71.20.6--Available----Yes--
WBC ADSL 2+Up to 12--10 to 13.5Available--------
WBC ADSL 2+ Annex MUp to 12Up to 110 to 13.5Available--------
ADSL MaxUp to 8--7 to 8Available--------
Fixed Rate2 ----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available
Message 7 of 20
You need to go back to the order team and insist that you haven't been upgraded despite what their systems tell them. They probably won't understand, but you can quote the modulation type shown by the HH is ADSL2
Message 8 of 20
Thanks guys
currently on the phone to someone in the UK
cheers
Moderator
Moderator
Message 9 of 20
Hi @elvispressley2016,
Did you get this sorted? Can you let me know how you're getting on? If you're stuck I'll be happy to lend a hand.
Cheers
David
Message 10 of 20
hi there no i never
im sorry but ur Indian call centre agents are beyond useless
all i need is for an engineer to come out and connect my line to fibre at the exchange
ive now been past to 5 different departments
