Guru
Guru
Message 11 of 19
Re: BT INFINITY CONTINUOUS DELAYS - POOR COMMUNICATION AND SERVICE
Hi kate1,
I think conrad's reply was to garethlevans.
In regards to your post, This forum is a BT Retail Customer to Customer help forum that is monitored by the BT Care forum moderators. Your posts do not go directly to BT Retail. To speak to BT Retail directly please visit this link: Contact BT
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
Message 12 of 19
I am not concerned with the intricacies of BT and Openreach.  Basically if BT reneges on its contract which it is now doing by not supplying BT infinity on the promised installation day, then I will be cancelling the contract if BT does this again.
Guru
Guru
Message 13 of 19
kate1,
Have you contacted BT Retail to rearrange a Openreach Engineer visit to install your BT Infinity service?
If you haven't then I would advise to contact BT Retail to re-arrange the appointment via this link: Contact BT
If the Openreach Engineer doesn't arrive on the next appointment time you have arranged with BT Retail and yourself then you can contact the BT Care Team by clicking on the link below.
Contact BT Care Team
The BT Care Team are a BT UK Based specialist team who have a good reputation for solving customer problems.
Once contacting them they will normally reply either by phone or email within 3 working days, however you will be given a tracking number immediately after sending the request. Please take note of this.
Please also note that during this holiday period there maybe a longer delay for you to get a response from the BT Care Team.
Cheers
Try a Search
Newbie
Message 14 of 19
BT are supposed to be escalating it due to their poor service.  However today was supposed to have been an escalated service and still the engineer did not arrive and I haven't been given a reason. I have already contacted the Care Team.  I've used them before, some of their replies have been helpful but others are only template replies which are useless as they are not tailored to my situation and therefore do not answer the questions - which frankly is even more annoying.
I do understand it's Christmas and it's all a bit late for todya, but for a communications company, your service has been atrocious.  However, at the end of the day, we want Infinity in, however, we are not going to continue to be messed around by BT, and BT only have one more chance to redeem themselves before I cancel my contract.   There are plenty of other options.
Message 15 of 19
What about this checker that people have said to check and shows you the actualy cabinet upgrade times/issues.
The link given just shows the exchanges whereas the admin under BT INFINITY FAQs states that it shows cabinet information after August 2012???
Guru
Guru
Message 16 of 19
Hi garethlevans,
The Openreach where and when website ( http://www.superfast-openreach.co.uk/where-and-when/ ) is the website that this post here: ( BT-Infinity-Availability-FAQs) is referring to. The website gives cabinet level information if there is a delay or if information is available on that cabinet's deployment timeframe. If information is available on that FTTC cabinet when entering your postcode a Yellow pin will appear. If you click on the yellow pin it will give more information.
To check the estimated date for when your FTTC cabinet is activated you can visit http://dslchecker.bt.com/adsl and enter your phone number or address. It may give you a estimated activation date for your WBC FTTC cabinet.
Cheers
Try a Search
Message 17 of 19
If you use this link http://www.superfast-openreach.co.uk/where-and-when/ then enter tis postcode it will give you an example of the cabinet information CT9 2NJ and information on how to contact Openreach for further details
Message 18 of 19
Thanks, however if i put my post code in RH16 4TS it shows no cabinet information.
Message 19 of 19
because as of this time Openreach have no current information on your cabinet
