Dear Sir/Madam,
My Broadband - Unlimited BT Infinity 1 connection was supposed to be activated yesterday 27/11/2014, but you did not activate it. You also changed the original date you promised and this is the second day you promised.
It says following message.
We are currently investigating your Broadband order with our suppliers and will keep you updated with any progress. Please continue to check online for further updates.
I am without broadband for almost more than 12 hours now. This is not a pleasent experience to get started. I would be greatful to you if you could look into my account and activate my connection at least today. Thank You.
Kind Regards, Resent User.
Solved! Go to Solution.
Hi RecentUser,
Please use the 'contact the mods' link in my forum profile under the 'about me' section to send in your details and we'll chase up your order with the suppliers. You can find the link by clicking on my username.
Neil
BT Infinity 1 Activation:
First date 24/11/2014 : Said the Order was lost in the system.
Second date 27/11/2014: Disconnected from my earlier supplier around 10.30 AM. Did not activate. Following message displayed.
1 Day late to activate.
