Hi,
I've had BT Infinity here since it was available to me (early 2011), and when first installed I got somewhere around 48 Mbps download, however over time it's dropped to around 30Mbps which has been frustrating, but still fast enough to do what I needed with it.
I've installed a new router today to replace the HH5, so have gone back to my old BT Openreach modem (together with an Asus RT-AC3200) which has given me the impetus to try and do something about the speed drop.
www.btwholesale.com/includes/adsl/main.html tells me I should expect what I previously was getting - 35Mbps+
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
HighLowHighLow
VDSL Range A (Clean) | 49 | 35 | 10 | 7 | -- | Available | -- | -- |
VDSL Range B (Impacted) | 37.2 | 20 | 8.3 | 4.7 | -- | Available | -- | -- |
However speedtest.btwholesale.com/ shows a 29.5Mbps download against an IPprofile set at 30Mbps
Download speedachieved during the test was - 29.15 Mbps
For your connection, the acceptable range of speedsis 21.01 Mbps-30.01 Mbps .
Additional Information:
IP Profile for your line is - 30.01 Mbps
Upload speed achieved during the test was - 6.57Mbps
Upstream Rate IP profile on your line is - 10 Mbps
I understand that 29Mbps with an IP Profile of 30Mbps is "acceptable", however it's this 30Mbps cap which is not.
Is there something I can do to find my 'missing' 18Mbps .. or someone I can contact who might be able to do something about it?
The master socket - it used to be an extension but a BT engineer moved it/converted it/whatever they do.
Line stats from the modem are here:
It says this:
We do have extensions, yes - but only one is in use.
They were here when the speed was higher too.
It says this:
# xdslcmd info --pbParams xdslcmd: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 8427 Kbps, Downstream rate = 39324 Kbps Bearer: 0, Upstream rate = 8427 Kbps, Downstream rate = 32399 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Discovery Phase (Initial) Band Plan US: (7,32) (871,1205) (1972,2782) DS: (33,859) (1216,1961) (2793,3970) Medley Phase (Final) Band Plan US: (7,32) (871,1205) (1972,2394) DS: (33,859) (1216,1961) (2793,3718) VDSL Port Details Upstream Downstream Attainable Net Data Rate: 8427 kbps 39324 kbps Actual Aggregate Tx Power: 5.8 dBm 12.2 dBm ==================================================================================== VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3 Line Attenuation(dB): 7.3 36.6 54.8 N/A N/A 18.1 45.1 69.4 Signal Attenuation(dB): 7.3 35.9 52.7 N/A N/A 25.9 44.8 70.5 SNR Margin(dB): 6.4 6.4 6.4 N/A N/A 8.6 8.7 8.8 TX Power(dBm): 0.3 -6.4 4.0 N/A N/A 10.0 7.9 -3.6 #
This is connected to the test socket - it doesn't look much different:
# xdslcmd info --pbParams xdslcmd: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 8454 Kbps, Downstream rate = 39560 Kbps Bearer: 0, Upstream rate = 8454 Kbps, Downstream rate = 32399 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Discovery Phase (Initial) Band Plan US: (7,32) (871,1205) (1972,2782) DS: (33,859) (1216,1961) (2793,3970) Medley Phase (Final) Band Plan US: (7,32) (871,1205) (1972,2376) DS: (33,859) (1216,1961) (2793,3516) VDSL Port Details Upstream Downstream Attainable Net Data Rate: 8454 kbps 39560 kbps Actual Aggregate Tx Power: 5.6 dBm 12.3 dBm ==================================================================================== VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3 Line Attenuation(dB): 7.3 36.5 54.7 N/A N/A 18.1 44.9 69.1 Signal Attenuation(dB): 7.3 35.9 52.4 N/A N/A 25.9 44.6 70.0 SNR Margin(dB): 6.8 6.3 6.2 N/A N/A 8.5 8.6 8.5 TX Power(dBm): 0.4 -6.5 3.8 N/A N/A 9.9 7.9 -1.2 #
