Keith_Beddoe
Message 11 of 41
Re: BT Infinity 1 speed constantly dropping
Its possible that the insataller "back wired" to socket in the dining room so that is was fed from the filtered side of the double socket in the living room.
The way to prove that is to do what I suggested, as that should stop the phone working. You can then replace it again.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
glenhill68
Expert
Message 12 of 41
Thanks.
I am at work at the moment but I have done the noise test and got no noise on the line.
glenhill68
Expert
Message 13 of 41
Didn't know if the master socket needs a filter for the phone.
Keith_Beddoe
Message 14 of 41
If the internal wiring has been done correctly, then it should not need one. You can usually tell if its wrong by picking up the phone, the broadband may disconnect, and you will hear noises on the line while it tries to re-connect.
As your broadband is only showing 39 minutes connection time, could that be the problem, or have you been restarting or disconnecting the home hub, as that will be seen as a line fault, and your speed will be reduced.
Its important that you leave the home hub alone, even if you run a speed test.
glenhill68
Expert
Message 15 of 41
Thanks.
The engineer did say I didn't need a filter. There's no noise on the phone and it doesn't disconnect the net.
The hub has been disconnected a few times recently, could this cause being banded?
Webby
Message 16 of 41
glenhill68
Expert
Message 17 of 41
Thanks and only an engineer can remove it
Webby
Message 18 of 41
Yep
glenhill68
Expert
Message 19 of 41
He is due to call Monday? Does he need property access?
licquorice
Message 20 of 41
