glenhill68
Expert
Message 21 of 41
Re: BT Infinity 1 speed constantly dropping
Oh right. I would have thought a banded profile was applied at the cabinet or exchange
Webby
Message 22 of 41
It is applied on by software that manages the DSLAM at the cabinet however, an engineer cannot request a reset without first finding a fault.
glenhill68
Expert
Message 23 of 41
Thanks for the reply.
I guess the fault is the speed drop which you indicated could be due to the hub being restarted alot.
glenhill68
Expert
Message 24 of 41
After 2-3 days of leaving the hub alone it must have restarted arounbd 8.40am this morning as it is showing as 6 hours 20 uptime.
The speed has now gone up to 40mb. Do you think it will continue to increase and I should cancel the engineer visit for Monday?
licquorice
Message 25 of 41
Can you post the line stats again now the speed has increased please. If it has gone up to 40Mb it looks as though DLM might be relenting.
glenhill68
Expert
Message 26 of 41
Thanks.
From within the router or the BTW test?
licquorice
Message 27 of 41
The router, but both won't hurt.
glenhill68
Expert
Message 28 of 41
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34538805
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 05/07/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 09:10:05
6. Data rate:6838 / 40352
7. Maximum data rate:7097 / 52420
8. Noise margin:6.3 / 5.5
9. Line attenuation:33.6 / 23.7
10. Signal attenuation:33.1 / 21.4
11. Data sent/received:8.6 GB / 24.2 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-PGJG
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:6
18. 5 GHz Wireless network/SSID:BTHub5-PGJG
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:48
22. Firewall:Default
23. MAC Address:18:62:2c:4c:18:e8
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
glenhill68
Expert
Message 29 of 41
licquorice
Message 30 of 41
Hmm, looks like the banding has been removed, but something is still not right. Your snrm is only 5.5 yet your attainable rate is much higher than your actual rate, maybe it is because G.Inp hasn't kicked in again yet. I would give it a week and see what happens.
