glenhill68
Expert
Message 31 of 41
Re: BT Infinity 1 speed constantly dropping
Thanks for the reply.
Is my SNR capable of 6.3?
What is G.Inp?
Should I cancel the engineer visit, I have until 2pm Sunday to do so?
licquorice
Message 32 of 41
Target snr is always 6.0dB.  G.Inp is a re-transmission technology that operates at the DSL layer rather than the TCP layer and can improve speed on error prone lines, have a read here
As to the engineer visit, difficult to say, unless he/she positively identifies a fault they won't be able to reset DLM anyway. Its a hard choice as your speed may or may not improve further but as it has improved beyond the lower limit of range A, it will be difficult to get an another engineer visit. On balance, I think I would still have an engineer visit.
pippincp
Message 33 of 41
Why 6.3? Target is 6.0 but will fluctuate around that.
G. Inp is an error correction technology
glenhill68
Expert
Message 34 of 41
Thanks for the replies.
That link too me to a Reevo page lol.
I will see if it improves again over the weekend. I was just mindful that BT mention about a hefty charge if no fault is found.
licquorice
Message 35 of 41
glenhill68
Expert
Message 36 of 41
Thanks, that's better. An interesting read.
Do you think with leaving my hub alone my speed will increase further, up to 47mb it was over Xmas.
I was prone to restarting the hub a bit too much.
glenhill68
Expert
Message 37 of 41
It says in the article G.INP isn't compatible with the Hub 5 Type A which I think mine is.
glenhill68
Expert
Message 38 of 41
It looks like the hub rebooted itself again around 7am this morning as it currently shows 6 hours uptime. Is this normal?
Speed still around 39mb.
pippincp
Message 39 of 41
The HH5 isn't compatable with the upload side if G, Inp that's why BT have only implemented it on the download side.
Ergo your HH5a is fully compatable with the implementation of G.Inp BT are running.
glenhill68
Expert
Message 40 of 41
Thanks for clarifying.
Today's stats:
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34538805
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 05/07/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 09:27:48
6. Data rate:6856 / 40000
7. Maximum data rate:6934 / 53341
8. Noise margin:6.1 / 6.0
9. Line attenuation:33.5 / 23.7
10. Signal attenuation:33.0 / 21.4
11. Data sent/received:8.9 GB / 35.4 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-PGJG
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:6
18. 5 GHz Wireless network/SSID:BTHub5-PGJG
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:48
22. Firewall:Default
23. MAC Address:18:62:2c:4c:18:e8
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
