Message 1 of 3
BT Infinity 1 speeds seem to have dropped recently - have I got a problem?
Hello,
I've noticed that my speed has dropped recently, where I was getting about 32Mbps on my iPhone I'm now down to around 17Mbps.  From reading another post, I wondered if the below is showing I have noise on my line?  Could somebody advise?
ie:  22.6 against an optimum of 19.8?  Am I right in thinking that causes DLM to kick in and slow things down?
1. Product name:BT Home Hub
2. Serial number:+068543+NQ41912680
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 31/07/14
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 16:28:40
6. Data rate:10000 / 39993
7. Maximum data rate:28784 / 86909
8. Noise margin:22.6 / 19.8
9. Line attenuation:0.0 / 8.5
10. Signal attenuation:0.0 / 8.5
11. Data sent/received:311.4 MB / 353.8 MB
2 REPLIES 2
Recognised Expert
Message 2 of 3
Re: BT Infinity 1 speeds seem to have dropped recently - have I got a problem?
You are getting the full infinity 1 speeds ie 40mbps download and 10mbps upload. I would not trust an iphone speed test as they are not capable of getting the max out of a connection due to WiFi and hardware limitations. Use a hardwired computer to test. But it does look like everything is ok.
Message 3 of 3
Ah, great.  Thanks for your help... I'll try some other bits to try and get the speed up over WiFi.
