j0n
Message 1 of 2
BT Infinity 2 Installed today - Very Poor Speeds
Hi,
I have just had BT Infinity 2 installed today to an Openreach Engineer. The BT Wholesale Checker shows the following for my number:
FTTC Range A (Clean) 59.3 43.7 16.2 10 -- Available
FTTC Range B (Impacted) 49.7 26.7 16.2 7.4 -- Available
But a wired speedtest.net result comes back with: just 22Mbps http://www.speedtest.net/my-result/3287469432
The Hub5 is plugged directly into the new faceplate that has been installed - and i dont have any extensions or anything like that to confuse things.
I have gone into the Hub 5 connection status which shows:
VDSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 04:43:37
Downstream: 23.38 Mbps
Upstream: 5.45 Mbps
What can I do? as a 20Mb line is not much more impressive than the 7Mb i was getting on my traditional ADSL line.
Jon
1 REPLY 1
GarethjWilliams2014
Message 2 of 2
Re: BT Infinity 2 Installed today - Very Poor Speeds
i would suggest leaving it for 10 days see if things improve as they do say there is a 10 day training phase, if nothing improves after that then i would come back see if you can get a mod to help you out as they are a good bunch here all uk based
