pokchop
Message 31 of 42
Re: BT Infinity 2 Upgrade Question
SpencerJ
Message 32 of 42
similar except my ip profile matches the speeds im getting... ive actually contacted the mods now, I am not willing to sit around for another week doing nothing. Ill see what they say.
SpencerJ
Message 33 of 42
ok, well now im getting between 2.5 and 3mbits down and up is between 3.5 and 3.8! whats going on?
SpencerJ
Message 34 of 42
Webby
Message 35 of 42
You've been on this forum long enough to know there are known issues with the BT speedtest - or you should do.
Test at www.speedtest.bbmax.co.uk using an Ethernet connection.
SpencerJ
Message 36 of 42
SpencerJ
Message 37 of 42
Yes, I have also been here long enough to know that people ask for IP profile, You sounded a bit annoyed in that last reply, well trust me its nowhere near as annoyed as I am right now. I was in the process of posting the other tests 😉
Webby
Message 38 of 42
So most of the time you're getting close to what your IP profile is. With the exception of this morning. Have you rebooted your home hub?
SpencerJ
Message 39 of 42
Yes im getting close to my pre infinity 2 speeds and ip profile, My issue is that before upgrade, and the the reason I upgraded is i was quoted 44.8 down and 8 up.... Rebooted hh3 and speed is back to 24 ish.
Webby
Message 40 of 42
If you're out the 10 days, call up. You need an engineer.
