stiel
Message 1 of 18
BT Infinity 2 at new home not delivering promised speed
Hi,
I had my 76Mb Infinity 2 moved to my new place since mid August and was promised a speed somewhere between 42-52Mbps. Since day 1 the speed has been below 40 Mbps. I've had 2 on site engineer visits already. The first engineer changed the main socket wiring which doubled my upload speed but download speed remains below 40 Mbps. Since his line test was clear he was thinking that my line may have the slower profile applied and suggested that BT should apply the 80Mbit profile. I've tried to address this a couple of times with the helpdesk and they send out an engineer again but without any results.
Output from the broafband checker:
BT BROADBAND AVAILABILITY CHECKER
Telephone Number on Exchange EAST LEAKE is served by Cabinet 6
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
69.4
51.2
20
14.1
44.6
Available
VDSL Range B (Impacted)
55
32.2
17.1
7.7
25
Available
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 11
6.5 to 15
Available
WBC ADSL 2+ Annex M
Up to 11
Up to 1
6.5 to 15
Available
ADSL Max
Up to 6
5 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise environment
Status
Bridge Tap
N
VRI
N
NTEFaceplate
N
Last Test Date
18-01-1970
 Output from the SmartHub:
Hopefully my download speed can be increased.
Kind regards,
Sander
17 REPLIES 17
XRaySpeX
Recognised Expert
Message 2 of 18
Re: BT Infinity 2 at new home not delivering promised speed
If you were promised a speed somewhere between 42-52Mbps, it's not worth being on Infinity 2.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
DavidM
Moderator
Moderator
Message 3 of 18
Hi @stiel and welcome.
Can you please try running the speed test including the further diagnostics and post the results?
Cheers
David
imjolly
Message 4 of 18
your attainable speed from router stats is 45mb and that will be the same regardless of package
XRaySpeX
Recognised Expert
Message 5 of 18
Not always! How many times do we see diff max. speeds from same connection at diff times? It's not set in stone!
imjolly
Message 6 of 18
the max attainable speed is not controlled by being on infinity 1 or 2.  it may vary at times, mine does, but that has nothing to do with the infinity package
XRaySpeX
Recognised Expert
Message 7 of 18
I would say Max. Speed is independent of the Infinities, as you can't say it won't change when you switch between them.
stiel
Message 8 of 18
DavidM
Moderator
Moderator
Message 9 of 18
Thanks for posting the results @stiel. Do you happen to know what your point of sale speed was? It would have been in your order confirmation.
Cheers
David
stiel
Message 10 of 18
Hi David,
My order confirmation states the following:
We estimate your download speed will be between 48Mb and 65Mb, and your upload speed will be between 12Mb and 18Mb.      The minimum guaranteed speed you can expect from your broadband will be 41Mb.
If there's no improvement in speed I plan to cancel the contract because I'm paying for the 76Mbps line.
Regards,
Sander
