sorrydarren
Message 1 of 5
BT Infinity 2 - but engineer has installed a Type 1 master socket... Query?
I've just moved home and using the home move service had an engineer visit my new house (I was at work my girlfriend let the engineer in). When I returned the engineer had fitted a Type 1 master socket - so no ADSL.
I've phoned BT to tell them the wrong socket is installed and their only solution is to tell me to use microfilters!?
But everything I read says microfilters are for Infinity 1 users, and 2 should be a Type 5 master socket.
I'd like some advice, I'm at the end of my tether...
Darren
4 REPLIES 4
imjolly
Message 2 of 5
Re: BT Infinity 2 - but engineer has installed a Type 1 master socket... Query?
microfilters are used for adsl and vdsl2 - filters should work ok on adsl - have done for years
Webby
Message 3 of 5
Yep, nothing wrong with using filters on Infinity. Most installs are now "self installs" so many many customers will still have older type sockets and will therefore require filters.
sorrydarren
Message 4 of 5
Thanks both, so no need to worry about the speed being slower using the microfilter rather than the built in filter on a Type 5 master socket?
I was concerned as the engineer fitted the master socket (I had no BT sockets in the house), so wanted to make sure he hadn't made a mistake and fitted old technology.
Webby
Message 5 of 5
There should be no difference in speeds at all. If there was, it certainly wouldn't be noticeable (a couple of kbps at worst)
