scotto52
Message 1 of 10
BT Infinity 2 installed but slow speeds
I've had my BT Infinity Unlimited 2 package installed on the 20th of March, lured in by BTs promise of between 75-80mbs download speed, but am still only getting 19 (sometimes less) according to http://www.speedtest.bbmax.co.uk/.
How long will it be before I see the (promised) speeds? Its been 7 days so the line should be settled in by now!
9 REPLIES 9
runamonk
Message 2 of 10
Re: BT Infinity 2 installed but slow speeds
That test is **bleep** and very inaccurate.
Have you tried Speedtest and ADSL Checker?
scotto52
Message 3 of 10
Just tried Speedtest and this came out at 21mbs so not much difference really.
runamonk
Message 4 of 10
What does BT adsl checker report? Can you post the line stats on your modem?
scotto52
Message 5 of 10
ADSL Checker shows:
                        Downstream Line        Upstream Line    Downstream Range      Availability
                        High        Low            High   Low
FTTC Range A    80           72.2           20      19.9                 --                      Available
FTTC Range B    80           60              20      17.9                 --                      Available
According to Speedtest my Upload was 19mbs so this seem fine.
runamonk
Message 6 of 10
What are the line stats on your modem? If those are similar then the problem isn't with the BT service but with your computer or with your actual router. Getting closer.
scotto52
Message 7 of 10
How do I get the modem line stats?
scotto52
Message 8 of 10
OK I figured how to get this now from the Hub:
Downstream: 63.65 Mbps
Upstream: 18.8 Mbps
runamonk
Message 9 of 10
Well unless there is a dns/path issue your connection looks good so far as throughput goes. Although it's interesting that your actual speed tests are coming in pretty low.
PC
Recognised Expert
Message 10 of 10
So it looks like your getting a good speed into the HH5.
Are you connecting to a laptop via wireless?
If so is it a wireless g or n.
Wireless g will only give about 25Mbps even when sitting next to the HH.
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
